Hi Folks,
A quick question to make sure I am not going mad.. just putting the top end back together all the marks line up 28th link on the correct cam shaft cog... Currently the cam cover is off but when I turn it over (with a spanner on the crank) there is one point in the rotation where the cam chain is slack and the idler cog is doing little.
Is this normal?
The bike is supposed to run the hill at Prescott tomorrow :-) Thanks in advance for any comments.
Paul
Cam Chain tension
Re: Cam Chain tension
not normal.
have you set to TDC and released the cam chain tensioner to take up the slack ?
As said defo not normal,wouldnt want to be running that on a hill climb till you sort that out.
Thanks PAULJAC47 and Chrsu.
Its on the trailer to go to Prescott but I am not running it..
Paul
Paul
Did you get this sorted ?
Either the tensioner is backing off/not locked or the camchain has slipped to one side of the crank and is not on the sprocket.
