Air Corrector Jets for 24,26 and 28mm Mikunis.Z650,Z1,Z9,Z1000.Also Suzuki GS 750,850,1000. £32 posted.
#1 PostAuthor: zed1015 » Wed Jun 20, 2018 3:16 pm
Air correction jets for VM and CV carbs.
For those not in the know these almost mythical and long out of production jets were originally designed and dyno developed by the legendary Leon Moss and marketed under the LEDAR brand.
These are essential when running your Mikuni VM26 - VM28 equipped Z1/Z900/Z1000 and Suzuki GS750/850/1000 without a stock airbox to correctly eliminate the low speed lean fueling condition flat spot that results.
Also suits Z650 VM24's.
Also improves running over the entire range with an average increase of two to six horsepower overall and provides a much needed level of added adjustability to the stock VM that was only previously available on the smoothbore versions.
Fitting these jets pinpoints the low speed fueling problem created by running open carbs or high flow filters and does not detrimentally richen the overall fueling the same as lifting the needles does which can result in up to 25% power loss and raised fuel consumption..
You will need to internally thread the air bleed in the mouth of each carb 8mm deep with an m5 x 0.8 tap (not included ) .
The air bleed orifice is already the correct tapping size so no drilling required.
See the attached pics for images of the jets and the THIRD pic for fitting reference with the correct position of the air bleeds highlighted and jets installed.
Also be aware of that some KAWASAKI VM26SS carb sets that are only equipped with the FUEL mixture screws underneath are made up of all left or right handed carb bodies..
In this instance the jets must be installed in the air passage furthest away from the unmachined air screw boss.
In the case of left hand bodies ALL the jets should be fitted at the 4 o'clock position and on right handed bodies all at 8 o'clock..
See LAST attached pic for example of a left hand body set with the jets installed in the 4 o'clock position..
Also available again for CV carbs on KAWASAKI ZR550A1, Z650, Z750L3. ,GT750, GPZ750,Z750 CUSTOM. Z1000J1/J2/J3/R, Z1100A1/A2/A3 - SUZUKI GS550 mx/mz Katana. GS650GT, 650 Katana 81, GSX750ET, GS850G, GS1000E/G, GS1100G, GSX1100 early and GSX1100G/KATANA.
These too require the jets to be installed in the 4 o'clock position on all CV bodies as they are not handed.
All types are £32.00 posted to UK for a set of four jets ( second pic )
(additional sets £29 on the same order)
Re: Z1,Z9,Z1000.AIR CORRECTOR JETS.
#2 PostAuthor: Pigford » Wed Jun 20, 2018 3:40 pm
I'll have a set please Rob.
#3 PostAuthor: zed1015 » Wed Jun 20, 2018 3:57 pm
Pigford wrote:I'll have a set please Rob.
:up
PM sent.
Simonic
#4 PostAuthor: Simonic » Thu Jun 21, 2018 12:02 am
I'll assume these are ok for an ST ?
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Thu Jun 21, 2018 1:28 am
aye:if it's running a 4-1 exhaust, n pod filters.
8 Valve Mark
#6 PostAuthor: 8 Valve Mark » Thu Jun 21, 2018 1:35 am
hi rob, ive got a set of mikuni 34mm cv carbs with these fitted, but one missing! any chance you would know the drilling size? or if you find an extra one kicking about.... cheers mark.. thanks
#7 PostAuthor: zed1015 » Thu Jun 21, 2018 8:05 am
8 Valve Mark wrote:hi rob, ive got a set of mikuni 34mm cv carbs with these fitted, but one missing! any chance you would know the drilling size? or if you find an extra one kicking about.... cheers mark.. thanks
Hi , Mark. Don't know if they used the same size drilling for the CV's but the instruction leaflet says for Mikuni CV's also and that they are not handed and go in the 4 o'clock position on all carbs
These are 0.5mm which I bet are close but any reduction over standard is a step in the right direction..
If unsure you would be better off replacing the whole lot as I only have full sets anyway.
#8 PostAuthor: chrisu » Thu Jun 21, 2018 11:37 am
can you send me a set please Rob.
I'll paypal you the £38.
#9 PostAuthor: zed1015 » Thu Jun 21, 2018 12:25 pm
chrisu wrote:can you send me a set please Rob.
PM sent.
#10 PostAuthor: zed1015 » Thu Jun 21, 2018 1:11 pm
Simonic wrote:I'll assume these are ok for an ST ?
Yes! Any Z9/1000 running VM 26/28mm round slide carbs without the airbox.
They also work with the Suzuki GS's with VM's and I also have them in my ex 1000 katana 32mm smoothbores.
KWACKERZ1
#11 PostAuthor: KWACKERZ1 » Thu Jun 21, 2018 3:56 pm
Just for info Grumpy 1260 stick new kits obviously not ledar ones but equivalents.
Hobbo
International Rep
#12 PostAuthor: Hobbo » Fri Jun 22, 2018 10:47 am
Rob
I will take a set please after discussion at Yorkshire I'm on hols at moment but Wi-Fi limited cheers
Phil
International Rep
#13 PostAuthor: zed1015 » Fri Jun 22, 2018 11:30 am
Hobbo wrote:Rob
Phil
Ok, Phil.
Will put a set to one side for you.
#14 PostAuthor: Pigford » Fri Jun 22, 2018 2:14 pm
Arrived today, cheers Rob :up
#15 PostAuthor: zed1015 » Fri Jul 06, 2018 2:14 pm
Bump.
Return to “For Sale”
