z1100 and z1000J compatability help needed
trikerdrew
#1 PostAuthor: trikerdrew » Tue Aug 07, 2018 11:02 am
Hi guys and gals,
Got a z1000J bottom end and want to know if the top end and covers(obvious not sprocket cover,LOL) from a z1100 will bolt on?
drew
Re: z1100 and z1000J compatability help needed
#2 PostAuthor: zed1015 » Tue Aug 07, 2018 1:15 pm
Should do as long as the top end isn't GPZ unitrack as the gudgeon pins are 18mm not 17 of the J.
Most z1100's are based on the J bottom with 17mm pins and a unitrack type head with shim over buckets.
Apart from that the actual castings and covers etc are a bolt on fit.
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Thu Aug 09, 2018 12:36 pm
So long as it has 17mm Gudgeon pins it'll fit on a J bottom end, as has already been said Unitrak engine has 18mm pins - this engine was also fitted to the Z1100R and the ZN1100 (US market custom style bike)
I thought Z1100s had the same head as a Z1000J and that the bath tub head was only fitted to the Uni type engine.
trikerdrew
#4 PostAuthor: trikerdrew » Mon Aug 13, 2018 8:33 am
Thanks guys.
Sharing your knowledge is what makes forums great
:D
