Z1000a Big bore head gasket
MikeSB6
#1 PostAuthor: MikeSB6 » Wed Oct 17, 2018 4:35 pm
Hello,
the Z1000a I'm rebuilding has been fitted with a big bore kit so that the bore is now around 74mm. Is there a big bore head gasket available which will fit this?
Cheers, MikeJ
Too much is never enough
Re: Z1000a Big bore head gasket
#2 PostAuthor: Philippe » Wed Oct 17, 2018 4:44 pm
Hi Mike
look at these:
http://z-fever.de/shop/product_info.php ... 35ccm.html
https://www.scheuerlein-motorentechnik. ... 1000a.html
I'm sure you can allso buy them in the UK but I don't know where.I think someone else can help you out
MikeSB6
#3 PostAuthor: MikeSB6 » Wed Oct 17, 2018 6:35 pm
Hello Phillipe,
many thanks for the reply and I'll check them out,
Cheers, MikeJ
#4 PostAuthor: Al » Wed Oct 17, 2018 7:05 pm
Either Debbens (01425 474628) or SPS http://www.suzukiperformancespares.co.u ... askets/64/ should be able to help with either an MLS or copper head gasket for youre size bore depending on what you want.
#5 PostAuthor: zed1015 » Wed Oct 17, 2018 7:35 pm
If it's a basic normally aspirated motor you want a Cometic cfm20 graphite fibre gasket.
Nick at Suzuki Performance spares can supply this one which suits 1075cc (72mm ) to 1135cc (74mm) bore.
http://www.suzukiperformancespares.co.u ... sket/1254/
Don't bother with copper unless you are racing and the MLS need a very clean and flat surface to seal which you will unlikely have unless the block and head have been resurfaced.
MikeSB6
#6 PostAuthor: MikeSB6 » Thu Oct 18, 2018 9:20 pm
Hello, thanks for the replies,
MikeJ
