I've been offered a set of Dyna 1 5 ohm coils by a friend and wondered if anyone has any experience of using them and mods required .
Cheers.
1.5 ohm Dyna coil fitting
Re: 1.5 ohm Dyna coil fitting
For what bike ?
Most zeds use 3ohm on points and 2.2 ohm on ic ignitors.
You can only use a higher resistance coil not lower otherwise you will overheat components.
The only use for the 1.5 ohm on the big zeds is to run 2 pairs in series to give the equivalent of two 4 pole 3ohm coils for use on duel plugged heads.
Users browsing this forum: No registered users and 77 guests
