Z900 a4 cylinder head
Has anyone got a good cylinder head for a z900 a4 76-77 for sale
Re: Z900 a4 cylinder head
I've got one, it's been welded, but doesn't affect operation. You can have it for £50 if it's any use.
Sounds good where has it been welded thanks
gaz wrote:Sounds good where has it been welded thanks
On the rear, not sure why it has been welded as was like that when I got it. I'll see if I can take some photos.
BTW - Has no cam caps, but I mght be able to rustle up a matching set if needed..
Sounds ok can you send some photos thanks
Hi don't want to push you the set of cam caps will help me out some photos will help me to thanks gaz
Sorry, been somewhat busy, will try to dig the head out.
Thanks it's much appreciated
