z1 cams
ogre
z1 cams
#1 PostAuthor: ogre » Fri Nov 30, 2018 11:33 pm
hi all fitted new valve guides and had valves cut and relapped in and i've come to check valve clearances and noticed my cams are andrews.going back to standard bore and pistons can these be used or is it best to use standard cams.
cheers ogre
ogre
Re: z1 cams
#2 PostAuthor: ogre » Mon Dec 03, 2018 10:14 am
hi all just checked cams says x2 on the end don't wanna build it up to find that these are only good for big bore engines some help would be appreciated.
cheers
Re: z1 cams
#3 PostAuthor: zed1015 » Mon Dec 03, 2018 11:06 am
Specs for the Andrews X2 cams are in the link below..
They are fairly mild, no need for a big bore and will run with stock valve springs.
http://www.andrewsproducts.com/files/assets/KZ900-1.pdf
Re: z1 cams
#4 PostAuthor: Ultim8pc » Mon Dec 03, 2018 11:10 am
I have a set of X2 cams. Bought them because they are a mild street cam, you shouldn't have any issues with them in a non-tuned bike.
ogre
Re: z1 cams
#5 PostAuthor: ogre » Mon Dec 03, 2018 12:43 pm
thats great thanks
Keefleaf
Re: z1 cams
#6 PostAuthor: Keefleaf » Mon Dec 03, 2018 4:03 pm
Got 2X in one of my Zeds :D work well :D
