Yoke material
chrisw1
Yoke material
#1 PostAuthor: chrisw1 » Sun Dec 09, 2018 10:17 pm
Hello . I need to repair a lock stop on a spare Z1 bottom yoke
What material are they made of and best welding method please
Re: Yoke material
#2 PostAuthor: kev edwards » Mon Dec 10, 2018 6:56 am
I think they are cast iron, and the best way is muggy welding, which most don't do.
Re: Yoke material
#3 PostAuthor: zed1015 » Mon Dec 10, 2018 12:20 pm
They are cast STEEL.
You can weld via Gas, Mig. Tig or Arc.
Probably best to use ARC in short bursts to build up a new stop.
chrisw1
Re: Yoke material
#4 PostAuthor: chrisw1 » Mon Dec 10, 2018 6:12 pm
Thanks ......I will look at it over xmas
Gavin
Re: Yoke material
#5 PostAuthor: Gavin » Mon Dec 10, 2018 7:42 pm
If using arc on a cast steel opt for a hydrogen controlled electrode
Less chance of cracking occurring in the heat affected zone
Z1000 MK2
Z1300 DFI
Re: Yoke material
#6 PostAuthor: kev edwards » Mon Dec 10, 2018 8:08 pm
I stand corrected, cast steel it is then, should be easy to build the repair up.
