vm28ss
8 Valve Mark
vm28ss
#1 PostAuthor: 8 Valve Mark » Fri Jan 18, 2019 2:01 pm
i recently bought some pumper carbs which came with no air screws or springs!!!. does anyone know how long they should be?? (screws +springs) probably the same as non-pump vm28 but I'd like to be sure before ending up with wrong ones. cheers in advance.. m
Re: vm28ss
#2 PostAuthor: warren3200gt » Fri Jan 18, 2019 2:26 pm
give the guys at Allens performance a ring to be sure. They will also have the parts you need.
http://www.allensperformance.co.uk/shop/
8 Valve Mark
Re: vm28ss
#3 PostAuthor: 8 Valve Mark » Fri Jan 18, 2019 2:48 pm
thanks Warren, I'll check the link, i have possibly sourced some already, but the seller has various lengths. I'm aiming to test run the carbs then possibly fit keyster kits if required. cheers m
Re: vm28ss
#4 PostAuthor: Ultim8pc » Fri Jan 18, 2019 3:41 pm
Mark,
I've got a set of 28mm pumpers from a 1000. I can check them and let you know if you'd like?
8 Valve Mark
Re: vm28ss
#5 PostAuthor: 8 Valve Mark » Fri Jan 18, 2019 3:54 pm
yes please nigel :lol: the top of the thread to the tip and the spring length would be much appreciated. thank you very large!! mark
Re: vm28ss
#6 PostAuthor: Ultim8pc » Fri Jan 18, 2019 5:09 pm
The ones fitted seem to be quite a way down the passage way so I'm wondering of not original or correct. However, they came off a running bike which had just been setup on the dyno...
24mm Total length
19mm tip to bottom of thread
I forget to measure thew spring length, but will do.
Hope this helps
8 Valve Mark
Re: vm28ss
#7 PostAuthor: 8 Valve Mark » Fri Jan 18, 2019 5:14 pm
that's great nigel, super rapid too..i hope you counted the turns on yours? :lol: cheers matey. m
Re: vm28ss
#8 PostAuthor: Ultim8pc » Sun Jan 20, 2019 10:50 pm
8 Valve Mark wrote:that's great nigel, super rapid too..i hope you counted the turns on yours? :lol: cheers matey. m
No worries, I'll need top remember to measure the spring length too..
8 Valve Mark
Re: vm28ss
#9 PostAuthor: 8 Valve Mark » Mon Jan 21, 2019 1:54 am
no rush mate,re springs; just whenever, if you can be bothered, screws are hopefully not an issue now thanks to your help.. cheers mark.
Users browsing this forum: No registered users and 122 guests
