No sure if I have seen this or I may be just making it up!
can you use two 7.5 mm disks on the z900a4 from end with the dual disk conversion or do I need 4.5mm disks. yes I have callipers etc.
am sue I saw something that said the two 7.5 would not fit, I haven't put the from end back together yet so I have not tried but thought I would ask the question first
dual disk
Re: dual disk
I have dual 7mm discs on my Z1B, cant imagine Z900 is different !
Re: dual disk
I have two 7.5mm discs on my kz900 as well. Just added a second one with the same thickness.
Re: dual disk
Thanks. Guys. I must have imagined it I could not think why it would make a difference but it’s always best to ask
Re: dual disk
Hi Derek
you can mount two KZ900 A4 or A5 7mm thick discs on the Z900A4 hub. The thick discs only increase the unsprung weight of the front wheel. But they fit as long as they have 4 holes for the disc bolts !
- ZedHead
Re: dual disk
By the time you have 2 x 7mm discs on the front you need another disc somewhere else to assist with stopping something that weighs as much as a half loaded artic. Have you ever dropped one of those 7mm discs on your big toe?
Cheers,
Mark.
Mark.
Re: dual disk
needaz1100r wrote:By the time you have 2 x 7mm discs on the front you need another disc somewhere else to assist with stopping something that weighs as much as a half loaded artic. Have you ever dropped one of those 7mm discs on your big toe?![]()
apologies could not resist.
- ZedHead
Re: dual disk
ADRIAN H wrote:needaz1100r wrote:By the time you have 2 x 7mm discs on the front you need another disc somewhere else to assist with stopping something that weighs as much as a half loaded artic. Have you ever dropped one of those 7mm discs on your big toe?![]()
Cheers,
Mark.
Mark.
