Gpz1100b1 seat lock
Gpz1100b1 seat lock
Guys, my Gpz1100b1 has a seat lock on the left hand side of the bike. Should there be one on the right hand side as well?? If not, what should be on the right hand side? I have seen a picture of a Gpz/J/R with a seat lock on the right hand side, so a bit more confused than normal. Any answers??
Re: Gpz1100b1 seat lock
From memory, the only seat lock where you put the key in is on the left. This allows removal of the seat, but also operates both helmet locks (one each side). I'll have to check when I get home this evening.
H2B GPZ900R
its a helmet lock
Another part to search for
My bad (memory !)
Yes, the right side helmet lock does need a key, and bolts on just behind the shock mount.
H2B GPZ900R
scott wrote:Another part to search for
Next to the Unicorns horn I believe you'll find one
Best of luck.
Well, I found the seat lock, which was apparently hens teeth. I’m sure I’ll find one eventually.
Found a helmet lock and bracket.....£15
Users browsing this forum: No registered users and 93 guests
