Z1a BHP
BigZCas
Z1a BHP
#1 PostAuthor: BigZCas » Thu Mar 28, 2019 2:44 pm
Does anyone know what the BHP should be at the rear wheel for a 1974 Z1a. (rebuilt engine).
Thanks :??
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Z1a BHP
#2 PostAuthor: chrisNI » Thu Mar 28, 2019 4:06 pm
Anybody's guess? I'd have thought 80bhp at the back wheel would have been good for a standard motor, a bit less not neccessarily a problem, a bit more very good. 50 or 60 not so good. Be interested to know are you taking one to a Dyno?
Re: Z1a BHP
#3 PostAuthor: ZedHead » Thu Mar 28, 2019 5:48 pm
Manual says maximum 82 @ 8,500 RPM. It does not mention where from, I would assume it is at the crank?
Re: Z1a BHP
#4 PostAuthor: zed1015 » Thu Mar 28, 2019 6:50 pm
Around 80 to 83hp at the CRANK for a stock 900 depending on year and what manual you read.
A little bit less at the wheel due to losses through the drive train and knock about 20 hp and 40 mph off the top end if fitted with one of those iffy restrictive pattern 4x4 pipes that were produced a while back..
tlc
Re: Z1a BHP
#5 PostAuthor: tlc » Fri Mar 29, 2019 6:23 am
I took BunnysZ1a to the local dyno.
It made 78 rwhp which I thought was very good.
Re: Z1a BHP
#6 PostAuthor: ZedHead » Fri Mar 29, 2019 7:40 am
tlc wrote:I took BunnysZ1a to the local dyno.
I would live with that. What pipes does it have Chris?
BigZCas
Re: Z1a BHP
#7 PostAuthor: BigZCas » Fri Mar 29, 2019 8:25 am
Looking at the readout I think the low HP (under 60), was due to the low RPM @ under 7000 :?:
Past 5 Years
1976 KZ1000a1, Red
Crofty
Re: Z1a BHP
#8 PostAuthor: Crofty » Fri Mar 29, 2019 8:57 am
Guy that dynoed my 650/810 told me to get at least a 1000 miles on the engine before giving it a hard time. He did some basic jetting to get it running ok to run engine in. Did your guy deliberately keep the revs down because it's been rebuilt or did it not want to go over 7000.
BigZCas
Re: Z1a BHP
#9 PostAuthor: BigZCas » Fri Mar 29, 2019 9:05 am
Rev's delibereatly kept low due to being a classic bike.
It was dyno'd to set up engine and carbs as they were only bench set previously, my bike has covered only 250 miles since full restoration.
Past 5 Years
1976 KZ1000a1, Red
Re: Z1a BHP
#10 PostAuthor: Ultim8pc » Fri Mar 29, 2019 9:37 am
I have a dyno printout of my ST somewhere. 59HP...
:oops:
rickm
Re: Z1a BHP
#11 PostAuthor: rickm » Fri Mar 29, 2019 9:53 am
I'm sure there must be plenty of dyno charts out there that folk can pitch in with.
I recall (back in the day) seeing in an American mag a dyno chart of a freshly run-in J which gave 79bhp at the wheel (Kawasaki claimed 102). They were speculating at the time whether this was reasonable transmission loss or maybe just a weak motor?
It would be interesting to get some more expert opinions here.
H2B GPZ900R
Re: Z1a BHP
#12 PostAuthor: ZedHead » Fri Mar 29, 2019 10:16 am
BigZCas wrote:Rev's delibereatly kept low due to being a classic bike.
Still running in at 250 miles
rickm
Re: Z1a BHP
#13 PostAuthor: rickm » Fri Mar 29, 2019 10:40 am
H2B GPZ900R
wheelysteve
Re: Z1a BHP
#14 PostAuthor: wheelysteve » Fri Mar 29, 2019 12:14 pm
Hi Steve, I trust you will be riding it down to the Ace Cafe .......that should run it in nicely and gain another 10 bhp !!
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
BigZCas
Re: Z1a BHP
#15 PostAuthor: BigZCas » Fri Mar 29, 2019 1:52 pm
I certainly will be Steve :) :)
We are planning for an early start, will be at the Ace for 9am ish.....
Past 5 Years
1976 KZ1000a1, Red
Users browsing this forum: No registered users and 106 guests
