Front break upgrade
Cabmonkey
Front break upgrade
#1 PostAuthor: Cabmonkey » Sun May 05, 2019 3:15 pm
Hi all
Could anybody tell me how I go about adding a second disc
Disc , calliper etc to my 1974 Z1b , as you know
they are double disc on later models so would
the existing wheel and forks work or need to replace them. Cheers
neilbarrett
Re: Front break upgrade
#2 PostAuthor: neilbarrett » Sun May 05, 2019 3:37 pm
you need second disc opposite caliper ,twin break line splitter ,second break hose ,twin disc master cylinder,fixing bolts etc,brake hose guide as well
#3 PostAuthor: Garry.L » Sun May 05, 2019 4:04 pm
Original twin brake set up also uses thinner disc's to reduce unsprung weight so you'd need to source 2 new discs if going down the factory route. ....
A1John
#4 PostAuthor: A1John » Sun May 05, 2019 4:18 pm
Never knew a z1b DD conversion used thinner discs, thought it was only z900/z1000 that used the thinner discs.
neilbarrett
#5 PostAuthor: neilbarrett » Sun May 05, 2019 4:51 pm
Garry.L wrote:Original twin brake set up also uses thinner disc's to reduce unsprung weight so you'd need to source 2 new discs if going down the factory route. ....
or have ya discs skimmed?
Charlie
#6 PostAuthor: Charlie » Mon May 06, 2019 7:51 am
The simplest way would be to shove a Z650C front end in. You can reuse your spoke wheel
CAT3
#8 PostAuthor: CAT3 » Mon May 06, 2019 5:46 pm
A1John wrote:Never knew a z1b DD conversion used thinner discs, thought it was only z900/z1000 that used the thinner discs.
Correct, the Z900-A4's came as standard in the UK with twin discs, which were thinner than the earlier Z1/A's/B's.
Upgrading the earlier Zeds to twin discs involved fitting a second thicker disc as the later thinner items had not been made at that point.
Also, the Z900 discs had four mounting bolts whereas I understand some of the earlier Zed discs had six mounting bolts.
Big Fluff
#9 PostAuthor: Big Fluff » Mon May 06, 2019 5:48 pm
BTW, GPz900R calipers fit straight on Z1000A2 for what it's worth, and work a helluva lot better than the standard single piston calipers.
8 Valve Mark
#10 PostAuthor: 8 Valve Mark » Mon May 06, 2019 10:30 pm
as already stated, the z1-z1b only came with a single 6 bolt disc, so the way ahead is to find a 2nd disc n the associated plumbing.the m/cylinder, 2nd caliper, pipes etc are readily available (or a PAIR of discs if poss?) look out for a drilled pair for best results. good luck. m
needaz1100r
#11 PostAuthor: needaz1100r » Tue May 07, 2019 6:01 am
8 Valve Mark wrote:as already stated, the z1-z1b only came with a single 6 bolt disc, so the way ahead is to find a 2nd disc n the associated plumbing.the m/cylinder, 2nd caliper, pipes etc are readily available (or a PAIR of discs if poss?) look out for a drilled pair for best results. good luck. m
:D :D :D
Cheers,
Mark.
needaz1100r
#12 PostAuthor: needaz1100r » Tue May 07, 2019 1:08 pm
Z1, Z1A and Z1B discs and brake calipers are different animals to the later single (thick) or twin (thin) discs.
Z1 series discs are 6 bolt mount, Z900A4 onwards are 4 bolt.
Caliper bolt spacings are different.
I have a pair of Z1 discs if you (cabmonkey) wants to PM me.
Cheers,
Mark.
rickm
#14 PostAuthor: rickm » Thu May 09, 2019 5:30 am
Big Fluff wrote:BTW, GPz900R calipers fit straight on Z1000A2 for what it's worth, and work a helluva lot better than the standard single piston calipers.
Would GPz900R callipers fit on a 1000J too ?
H2B GPZ900R
Users browsing this forum: Bing [Bot] and 99 guests
