Head studs
King of Kings
Head studs
#1 PostAuthor: King of Kings » Sat Nov 09, 2019 6:59 pm
Hey all, what’s the easiest way to fit new exhaust clamp studs? Every time they’re wound in, they come back out when removing nut, unless held/butchered in place with mole grips?
Re: Head studs
#2 PostAuthor: zed1015 » Sat Nov 09, 2019 7:07 pm
What nut are you using ..Lock nut ? and running it down to the plain portion to screw the stud in.
You need to lock two normal nuts together and tighten the stud in with a drop of Loctite.
Then unlock the nuts and remove them.
Stud shouldn't come out if tightened correctly.
Gus
Re: Head studs
#3 PostAuthor: Gus » Sun Nov 10, 2019 3:34 pm
Use a domed nut with a ball bearing inside to screw them in then the domed nut comes undone easily.
Gus
"Set the GRINDER on it"
Users browsing this forum: No registered users and 122 guests
