Carb ID...
Yellow
Carb ID...
#1 PostAuthor: Yellow » Sun Nov 17, 2019 6:47 pm
Hi, I have a set of CV carbs that came with a KZ1100 Spectre 1981 that I recently purchased. They are not the origional carbs for this bike. The markings on the are Keihin 173.9 UJ06. They have a choke lever (as oppost to a pull bar) and a butterfly choke system. The seal for the float bowl is a rubber seal not a gasket. They match up to the inlet rubbers on the bike and the air box rubbers are the correct size. I would like to know what bike these came on as i need to replace some bits on them...
Cheers.
Yellow
Re: Carb ID...
#2 PostAuthor: Yellow » Mon Nov 18, 2019 6:59 pm
Re: Carb ID...
#3 PostAuthor: z1bman » Mon Nov 18, 2019 8:08 pm
Yellow
Re: Carb ID...
#4 PostAuthor: Yellow » Mon Nov 18, 2019 8:30 pm
Thanks z1bman...
Users browsing this forum: No registered users and 116 guests
