Got 2 sets of carbs, what are they
Re: Got 2 sets of carbs, what are they
Both VM28SS.
One set probably Z1R with the tick over screw being underneath.
The other has the vac tap take off on #3 carb so maybe MK2 or ST.
Air correctors fitted to the second set.
Pic's of first set doesn't show the fronts.
Those are 28mm pumpers from a US model.
Probably MK2 or ST again with #3 vac port but don't know for sure with the US models if there was a vac tap on the Z1R's too .
Best of the bunch in good condition.
Should have just the square diaphragm on carb #2 functioning and the triangle one a blank casting.
Users browsing this forum: Kev1R and 80 guests
