gpz1100 MLS Cometic head gasket
pluto
#1 PostAuthor: pluto » Tue Jan 28, 2020 8:41 pm
Hi Folks, I need a new multi layer steel head gasket for my Gpz1100 with 1170 big bore kit, where is the best (cheapest) place to buy one these days?
Dave
KWACKERZ1
Re: gpz1100 MLS Cometic head gasket
#2 PostAuthor: KWACKERZ1 » Tue Jan 28, 2020 9:34 pm
Try Chris at Grumpy's he knows you so should give you a decent discount.
#3 PostAuthor: Al » Tue Jan 28, 2020 9:40 pm
Phil beat me to it. If he cant help there's Suzukiperformancespares, and Since Ray is supposed to have initiated this process, he might be worth a ring.
Dave do you know if they can be re-used? I have heard both a yes and a no to that question!!
scott
Junior Section leader
#4 PostAuthor: scott » Wed Jan 29, 2020 8:05 am
Al. got mine from Ray Debben last time but can't remeber the cost. :roll:
Julian_Boolean
#5 PostAuthor: Julian_Boolean » Wed Jan 29, 2020 9:00 am
Al wrote:Phil beat me to it. If he cant help there's Suzukiperformancespares, and Since Ray is supposed to have initiated this process, he might be worth a ring.
Chris says the multi layer metal gaskets can be reused.
My one cost about £70, which sounds a lot, but the genuine Kawasaki pair of gaskets are £35ish and can't be reused.
#6 PostAuthor: zed1015 » Wed Jan 29, 2020 9:23 am
You can re-use them if the Viton coating is intact but you still risk a higher chance of failure over a new one.
They also prefer a smoother machined block and head finish to what you can get away with a conventional fibre gasket so a pitted surface would benefit from a light skim to guarantee a perfect seal.
pluto
#7 PostAuthor: pluto » Wed Jan 29, 2020 7:29 pm
Thanks all - no one was answering their phone today so will try again tomorrow. This gasket is for my old B2 motor - the engine I was having all the trouble with now has a MLS gasket in it and has remained leak free for quite some time, long may that continue.
#8 PostAuthor: Al » Wed Jan 29, 2020 10:35 pm
Im sure there will be plenty about but if you get stuck i have a brand new one here you can have and replace in youre own time.
pluto
#9 PostAuthor: pluto » Sun Feb 09, 2020 11:38 am
Thanks Al, sorted with that but got other probs that mean the motot cant go back ytogether yet. :(
Users browsing this forum: No registered users and 77 guests
