front sprocket KZ650B
Road Runner
#1 PostAuthor: Road Runner » Wed Jan 29, 2020 3:02 pm
Whilst the Z1000 project is ongoing I've been a bit rash and got a KZ650B i978, just changing the chain and sprockets the old front sprocket has a hole for the tab washer to fit into the new sprocket has no hole. Any known fixes?
Ride Safe!
Re: front sprocket KZ650B
#2 PostAuthor: zed1015 » Wed Jan 29, 2020 3:12 pm
Loctite the nut or drill a hole for the tab..
Road Runner
#3 PostAuthor: Road Runner » Wed Jan 29, 2020 4:55 pm
My drills ain't doing it! Not sure I trust just loctite.
Ride Safe!
#4 PostAuthor: warren3200gt » Wed Jan 29, 2020 5:25 pm
Get a splined washer with fold over tabs that lock the nut from a later model.
#5 PostAuthor: zed1015 » Wed Jan 29, 2020 6:58 pm
Cobalt drill should do it .
Splined washer doesn't usually work on the early bikes as the shafts spline stops short of the sprocket face.
You can also use a clutch center lock nut as it's the same thread.
Users browsing this forum: No registered users and 152 guests
