J Engine Alternator Casing Wiring Plug
Has anybody got a spare plug for the Alternator casing on a J engine, I've removed my alternator and need to plug the hole in the casing, we have tried filling the hole with instant gasket but it leaks with a steady drip when the bike is on it's side stand. The plug isn't available as a separate part from the alternator coils, so I was wondering if anyone had an old one from an alternator they're not using that I could purchase.
Re: J Engine Alternator Casing Wiring Plug
Available from ZPOWER .
Nearly £14 before post though.
http://www.z-power.co.uk/alternator-cover-grommet
zed1015 wrote:Available from ZPOWER .
Do you know that it's the same as a J one as it says it's for the earlier engines.
Pretty sure it is.
Same part comes up if you search in Z1000J/Z1100.
Cheers I'll order one now
