cast alloy repair?
- 8 Valve Mark
cast alloy repair?
does anyone have any experience with regards to fixing a broken carbs' float post? it's a clean break above the pivot pin at about a 45 degree angle. possibly tig-able or with one of the wonder rods that you see on the interweb? any help or recommendations welcomed, it's a small fiddly job more suited to a jeweller than someone who fabricates pylons!
m
Re: cast alloy repair?
I have a vague memory of someone doing this on here and i believe they drilled first and put a peg or thin dowel in it and then got it welded.
If you cant find someone to do it send me a pic of whats involved.
It may be easier to build it up rather than stitch the original bit back on.
The super fastidious Brian at Centurion Motorcycle Projects has repaired quite a few:
https://www.facebook.com/centurionmotorcycleprojects
- 8 Valve Mark
thanks for the replies (Al and nigel) I will sort out some photos and send them to you Al. keep safe out there.. m
Send me a picture or post it on here Mark.
Ive spent a fair bit of time recently, building up un-obtainable cast and alloy moldings / components etc. with TIG but its not what i do. The lad i work with is eleventy million times better at it than me but as you guessed, its not that easy to find the correct method.. meaning rods etc.
