Points Plate Grommet
Niall M.
#1 PostAuthor: Niall M. » Wed Apr 01, 2020 5:40 pm
Hi All,
Looking for the grommet that's on the points plate cable that goes to the coils,there's a slot in the casing where it sits this is for a Z1A but I assume there the same across the Z range.
Thank's,
Niall.
Niall Mehigan
000zeds
Re: Points Plate Grommet
#2 PostAuthor: 000zeds » Wed Apr 01, 2020 7:17 pm
Niall I might have one will look tomorrow :!:
Have you tried Paul Doran :?:
Zeds-R-Us
Niall M.
#3 PostAuthor: Niall M. » Wed Apr 01, 2020 9:29 pm
Thank you 000ZEDS.
Niall Mehigan
000zeds
#4 PostAuthor: 000zeds » Thu Apr 02, 2020 6:02 pm
Niall I am sorry but no luck,
Try Paul Doran
Zeds-R-Us
Niall M.
#5 PostAuthor: Niall M. » Thu Apr 02, 2020 6:39 pm
Will do thank's for looking.
Niall.
Niall Mehigan
Kev1R
#6 PostAuthor: Kev1R » Thu Apr 02, 2020 10:54 pm
The grommet in question appears to have an odd shape in that it has a flat side and is 'D' shaped.
Just a suggestion -
I suppose until one turns up, you could use a 'normal' round (maybe slightly undersize) one with a smear of silicon which should seal against the elements ok.
At least it would allow use of the bike without fear of water ingress knocking the ignition out.
010
Niall M.
#7 PostAuthor: Niall M. » Fri Apr 03, 2020 6:38 pm
Kev,as you said it's D shaped hopefully one will turn up as the Z1A is a restoration project but nearly there now just the carbs and wiring harness to fit and we'll see how it goes,thank you for your suggestion.
Niall.
Niall Mehigan
#8 PostAuthor: Bill P » Fri Apr 03, 2020 9:53 pm
Ive previously cut one out of rubber to shape , seem to remember the hole was a pain in the arse .
got a few points set up now i've removed for electronic ignition so will have a look for one
Niall M.
#9 PostAuthor: Niall M. » Sat Apr 04, 2020 10:43 am
Thank's Bill.
Niall.
Niall Mehigan
73z1
#10 PostAuthor: 73z1 » Sat Apr 04, 2020 4:08 pm
Niall M.
#11 PostAuthor: Niall M. » Sat Apr 04, 2020 5:58 pm
Thank you 73z1 it's an option if a grommet dose'nt turn up.
Niall.
Niall Mehigan
Niall M.
#12 PostAuthor: Niall M. » Thu Apr 09, 2020 7:11 pm
All sorted now thanks to Bill P a gent,and Thank you to ALL who make suggestions/options.
Have a good Easter in whatever shape or form.
Niall.
Niall Mehigan
