Resistor plug caps
AlanB
Resistor plug caps
#1 PostAuthor: AlanB » Tue Apr 07, 2020 11:14 pm
Can I fit resistor plug caps (say NGK LB05F) to non resistor NGK B8ES PLUGS ? Cheers all :lol:
Re: Resistor plug caps
#2 PostAuthor: Pigford » Wed Apr 08, 2020 6:22 am
I think they’ll work okay, but you can take the little resistors out by unscrewing the inner brass connector (the bit that fits to the spark plug) and remove it and use a short bit of metal to replace it - you can cut up a small bolt or similar.
Careful not to loose the tiny spring!
#3 PostAuthor: zed1015 » Wed Apr 08, 2020 10:11 am
Yes!
As long as you have only one source of resistance you are ok.
floydsz1
#4 PostAuthor: floydsz1 » Wed Apr 08, 2020 11:09 am
I thought I'd been using those caps and plugs all the time and just used them as they were.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
