Z Power Z900 Loom
Andrew_s
Z Power Z900 Loom
#1 PostAuthor: Andrew_s » Fri Apr 17, 2020 11:51 am
I'm considering replacing the main loom on the Z900 with the Power aftermarket one which seems good value after the club discount is applied - http://www.z-power.co.uk/wiring-loom-z900a4
Can someone advise if the UK and US spec looms vary widely (e.g PO switch) or whether the Z Power loom is a straight fit on a UK bike?
Any fitting advice gratefully welcomed.
Cheers,
Andrew
Current Bikes:
2023 R1250 GSA
Re: Z Power Z900 Loom
#2 PostAuthor: Ultim8pc » Fri Apr 17, 2020 11:57 am
I'm fitting one at the moment to repro switchgear and seem to have some extra blue wires I need to figure out....
So not straightforward.
Andrew_s
#3 PostAuthor: Andrew_s » Fri Apr 17, 2020 12:01 pm
Ultim8pc wrote:I'm fitting one at the moment to repro switchgear and seem to have some extra blue wires I need to figure out....
Thanks Nigel, thought it might not be - my switchgear is original.
Cheers,
Andrew
Current Bikes:
2023 R1250 GSA
#4 PostAuthor: Ultim8pc » Fri Apr 17, 2020 2:37 pm
Andrew,
The bike I have with the repro harness is a 3/4 finished resto I picked up and it's all repro stuff on it.
Normally, I'd just (just!) repair and recover the original harness.
Andrew_s
#5 PostAuthor: Andrew_s » Fri Apr 17, 2020 5:16 pm
Ultim8pc wrote:Andrew,
Yes, I'm leaning that way too Nigel as the worst bit is inside the headlight shell and other minor bits can be repaired.
Current Bikes:
2023 R1250 GSA
SVENLEATHER
#6 PostAuthor: SVENLEATHER » Fri Apr 17, 2020 7:17 pm
Tell me about problems in the headlight area.
Andrew_s
#7 PostAuthor: Andrew_s » Fri Apr 17, 2020 8:55 pm
Tell me about problems in the headlight area. EA295E1D-9A8A-4898-B5B6-369181F7874E.jpeg
Ouch! :shock:
Current Bikes:
2023 R1250 GSA
weaver
#8 PostAuthor: weaver » Sat Apr 18, 2020 4:19 am
Most looms can be repaired easily enough unless they have been totally hacked about,good skill to develop and its not difficult :wink
#9 PostAuthor: chrisu » Sat Apr 18, 2020 10:21 am
Agree there are some extra blue wires but it was a great plug and play replacement for the original knackered loom on my Z900 (aka the moneypit)
#10 PostAuthor: Ultim8pc » Sun Apr 19, 2020 12:56 pm
chrisu wrote:Agree there are some extra blue wires but it was a great plug and play replacement for the original knackered loom on my Z900 (aka the moneypit)
I have mine in place with repro switchgear and everything is working except the horn, so I need to figure that out....
scott
Junior Section leader
#11 PostAuthor: scott » Mon Apr 20, 2020 7:42 am
Nigel, i had the same issue with my z1000a2 harness and switch gear.....as soon as i clamped the switch gear to the handlebars then the horn worked. It needs the earth connection to work, via the clamping.
#12 PostAuthor: Pigford » Mon Apr 20, 2020 8:14 am
Yeah, the horns are daft, they have a constant live feed (with ignition on) and rely on the switch to earth it to get it to work!
#13 PostAuthor: Ultim8pc » Mon Apr 20, 2020 10:20 am
Pigford wrote:Yeah, the horns are daft, they have a constant live feed (with ignition on) and rely on the switch to earth it to get it to work!
I have permanent live on one connector and the other end is switching to earth (used beep tester to check that) and the horn works on another bike....
#14 PostAuthor: chrisu » Mon Apr 20, 2020 11:56 am
Is the right hand switch body earthing ok ? I had this problem with a repro switch. i think this is how the horn earths
#15 PostAuthor: Ultim8pc » Mon Apr 20, 2020 1:05 pm
chrisu wrote:Is the right hand switch body earthing ok ? I had this problem with a repro switch. i think this is how the horn earths
Dunno, will check.
