Glass fuses
Farmer
Glass fuses
#1 PostAuthor: Farmer » Mon May 25, 2020 11:33 am
Good afternoon guys,
Does anyone have a link to buying 12v Glass fuses 1” length 30amp fuses, all on eBay are 30mm
TIA
1981 KZ1000 K1 LTD
Farm Boy with an O Level in Metalwork and not much else.
Everything in Sussex is a She, Except Tom Cat and She`s a He.
Re: Glass fuses
#2 PostAuthor: Pigford » Mon May 25, 2020 12:07 pm
Re: Glass fuses
#3 PostAuthor: Al » Mon May 25, 2020 12:45 pm
This is fairly much a direct replacement for the frail standard fuse box with a little jiggery pokery and enlarging a couple of holes with a drill.
It is not the most robust but better than the original which corrodes round the ring terminals on the underside and in my case; cracked invisibly!!!
https://www.vehiclewiringproducts.co.uk ... e-fuse-box
Fuses here
https://www.vehiclewiringproducts.co.uk ... blade-fuse
Zedorset
Re: Glass fuses
#4 PostAuthor: Zedorset » Mon May 25, 2020 2:57 pm
I did away with the fuse holder buy using two female Japanese spade connectors and a car bayonet fuse, although not original it isn’t an issue if you need to replace a fuse.
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Users browsing this forum: chrisu and 70 guests
