3.4 bulbs
sweptail
3.4 bulbs
#1 PostAuthor: sweptail » Wed Jun 10, 2020 6:07 pm
Am I right in thinking that 4 watt Bulbs will be brighter than 3.4 watt? ( idiot lights).. Ta
z2.john
Re: 3.4 bulbs
#2 PostAuthor: z2.john » Wed Jun 10, 2020 8:36 pm
yes
KWACKERZ1
Re: 3.4 bulbs
#3 PostAuthor: KWACKERZ1 » Thu Jun 11, 2020 8:14 am
Yes but 4 w will generate more heat,
I had the neutral light green backing melt when using the wrong bulb.
Personally i would use he correct round bulb (expensive from z-power) but the longer more readily available hence cheaper and longer bulbs can run to close to the plastic cover on zed clocks.
KWACKERZ1
Re: 3.4 bulbs
#4 PostAuthor: KWACKERZ1 » Thu Jun 11, 2020 8:23 am
Although you could use the longer bulbs in the speedo and tacho for ilummination without problems.
sweptail
Re: 3.4 bulbs
#5 PostAuthor: sweptail » Thu Jun 11, 2020 3:12 pm
Thanks for that kwaker. A melting neutral backing plastic is the reason I want to use the shorter ones. Tho I will use the longer bulbs in speedo/ tach. The short 3.4 bulbs are available from India if required Tommy
Gus
Re: 3.4 bulbs
#6 PostAuthor: Gus » Thu Jun 11, 2020 3:49 pm
Could fit LED replacements.
Gus
"Set the GRINDER on it"
KWACKERZ1
Re: 3.4 bulbs
#7 PostAuthor: KWACKERZ1 » Thu Jun 11, 2020 3:53 pm
Gus,
If you have a link to suitable led ones that would be great.
Gus
Re: 3.4 bulbs
#8 PostAuthor: Gus » Thu Jun 11, 2020 3:57 pm
Here's one but I think there are more manufacturers
https://www.autoelectricsupplies.co.uk/ ... tegory/119
Gus
