GPZ1100 B1 project now sold
Z1B
#1 PostAuthor: Z1B » Sat Aug 08, 2020 8:49 pm
SOLD, Bought this GPZ, 20 years ago, with an engine problem, broken ring on one cyl, the other 3 cylinders would clean with a hone, scored cylinder needs liner and piston, and basically a full set x4 of rings, wiring harness is in a bag, (was originally going to make a special), this came with carbs instead of injectors, it was a runner when bought though slightly smokey, 95% their, good project for someone, micron fork brace, ZRX1100, shocks, 27,000 miles, how much to ask what's your thoughts guys.
Always Learning. :wink
dbee
Re: GPZ1100 B1 project
#2 PostAuthor: dbee » Fri Aug 14, 2020 5:40 pm
hi is this still for sale
1962royp
#3 PostAuthor: 1962royp » Thu Aug 27, 2020 12:02 pm
Thats a unitrac ignition rotor.
I could be interested if its still for sale?
GPZ1100 B2 owner
GPz 305 project
99% Gpz1100 unitrac Nearly there runs just needs paint.
1100 Zephyr Project.
1981 KZ1000 LTD
Julian_Boolean
#4 PostAuthor: Julian_Boolean » Thu Aug 27, 2020 12:40 pm
Pistons don't look like Uni ones, if the carbs are 33s they're worth £250
#5 PostAuthor: zed1015 » Thu Aug 27, 2020 12:45 pm
GPZ1100 B1 motor ( injectors in the head )
Normal 26mm or 28mm VM carbs.
Andy M
#6 PostAuthor: Andy M » Fri Aug 28, 2020 9:46 pm
Price ???
Z1B
#7 PostAuthor: Z1B » Sat Sep 19, 2020 10:03 am
Im not on this site much, tend to use Facebook, apologies GPZ is long sold, ill see if i can add to post or delete.
#8 PostAuthor: zed1015 » Sat Sep 19, 2020 11:22 am
You can just edit the first post and put Sold in the title.
Return to “For Sale”
