Billet engine mounts
John0622
#1 PostAuthor: John0622 » Thu Aug 27, 2020 8:02 pm
I'm after a set of alloy billet engine mounts for a Z1000 A2, I believe all the 900 and 1000 variations share the same mounts, correct me if I'm wrong. New or used would be fine and any new bolts that need to go with them. I was recommended them many years ago by Stuart at Big Four Engineering. Whatever happened to him? Thank you.
Hobbo
International Rep
Re: Bill engine mounts
#2 PostAuthor: Hobbo » Thu Aug 27, 2020 8:48 pm
Z power supply them from pmc
International Rep
#3 PostAuthor: chrisNI » Fri Aug 28, 2020 8:19 am
John0622 wrote:I was recommended them many years ago by Stuart at Big Four Engineering. Whatever happened to him? Thank you.
I think he disappeared of into the hills to play with mountain bikes :D
flateddie
#4 PostAuthor: flateddie » Fri Aug 28, 2020 1:29 pm
I got mine for my z1000a1 from Cybike
John0622
Re: Billet engine mounts
#5 PostAuthor: John0622 » Sun Aug 30, 2020 12:06 pm
Thanks for the answers, I saw that Z power arent doing them but Cybike are - very expensive. I spoke with a member nad he told me he had made his own so i fancy having a go at that and have bought some 10mm plate. Need to think about a decent aluminium file now!
#6 PostAuthor: zed1015 » Sun Aug 30, 2020 12:36 pm
You should make the holes an accurate fit for the bolts unlike the sloppy stock ones.
That will help stiffen the frame slightly.
Hobbo
International Rep
#7 PostAuthor: Hobbo » Sun Aug 30, 2020 12:47 pm
John0622 wrote:Thanks for the answers, I saw that Z power arent doing them but Cybike are - very expensive. I spoke with a member nad he told me he had made his own so i fancy having a go at that and have bought some 10mm plate. Need to think about a decent aluminium file now!
Not on z power website but ring phil sure he supplys them cheaper than others
Phil
International Rep
neilbarrett
#8 PostAuthor: neilbarrett » Sun Aug 30, 2020 1:42 pm
Try webike
You get full kit anodized with matching bolts .
