GPZ1100A Unitrack head complete with all stock valves, buckets, shims etc and its original cam caps..
No broken fins, fin repairs or external damage.
Needs a re-fresh, ideally fresh guides, a valve job and repaint etc.
All threads good. Helicoil on number 2 plug.
Has been drilled and machined for APE idler for use on early motor ( last pic ) but those can easily be blanked for normal GPZ use.
Has had 30mm deep M10 steel inserts fitted and tapped back to m6 in all 16 cam cap bolt holes to salvage all the snapped bolts and stripped out helicoils that were horrendously butchered by a PO - See PIC 1.
These will never strip.
Was going on my turbo build and only selling due to change of piston type and the use of a 'J' head.
Prefer cash on collection and personal inspection welcome so you know and understand what you are getting .
£300 .
SOLD ... GPZ1100A UNITRACK CYLINDER HEAD.
Re: SOLD ... GPZ1100A UNITRACK CYLINDER HEAD.
Thanks Rob, turned up today....packaged to within an inch of it's life. It was like doing the krypton factor just trying to get in.
Very happy indeed.
Thanks again Rob.
Very happy indeed.
Thanks again Rob.
