Harris Exhaust
stempy
Harris Exhaust
#1 PostAuthor: stempy » Sat Sep 19, 2020 8:07 pm
Wanted Harris exhaust , can be perfect or scrap condition ,
Regards
Stempy
PUM 451
MikeP
Re: Harris Exhaust
#2 PostAuthor: MikeP » Mon Sep 21, 2020 6:14 am
Hi Stempy,
Are you still after a Harris set of pipes?
Cheers, Mike
stempy
Re: Harris Exhaust
#3 PostAuthor: stempy » Mon Sep 21, 2020 9:38 pm
Yes please Mike
PUM 451
MikeP
Re: Harris Exhaust
#4 PostAuthor: MikeP » Tue Sep 22, 2020 10:59 am
This came off my ST which I've tarted up. The downpipes were wrapped in that awful cloth tape so a few are pitted but pretty solid and no holes. For some reason, the header clamps are welded to the pipes but still my Gpz1100 B1 with no problems. It's got a track baffle but I've wrapped to reduce the noise slightly and tucked the offending "not for road use" to the back. I've got a bracket to attach to the two nuts located in a channel but you'll probably want to make one yourself outa stainless or steel sheet.
I was gonna keep it, hence the tart up, but gonna find an original set of pipes for the B1. How does £200 incl postage in the UK sound?
Mr Bump
Re: Harris Exhaust
#5 PostAuthor: Mr Bump » Tue Sep 22, 2020 8:42 pm
Got a scrap one that fitted a gpz1100b if you want it...
Olly
Lemmy
