I’m in need of an airbox to fit CV carbs to my Unitrak1100. Any airbox from a from a CV carb’d Z or GPz. Would consider a 750, 1000 or 1100. Any condition as I might have to do some work to make it fit.
Thanks,
Paul
Airbox wanted
Airbox wanted
A2 1979-80. A1 1980-now
Re: Airbox wanted
Hi I have an air box from a Z1000 ltd 1980 with CV carbs, if any use.
Re: Airbox wanted
Hi, quite possibly. Can you take some pics of it and measure the front to back distance of the base please.
- paul doran
Re: Airbox wanted
Here are a few pictures, it’s 150 mm the base from front to back, the lid is missing and the rubbers are solid, if it’s any use you can have it, just cover the postage.
Re: Airbox wanted
I think that will fit. I’d like to give it a go. Let me know the cost. In the meantime I’ll PM you my details.
- paul doran
Re: Airbox wanted
It will fit straight in its the same as a J
I have used one on an unitrack with no issues
Re: Airbox wanted
Thanks Paul. Walshyco’s looks like a J type box. Apart from the anti-pollution mods, I think the same pattern box was fitted to all the CV carb’d models.
