dyna s
keith mayall
dyna s
#1 PostAuthor: keith mayall » Sat Nov 28, 2020 6:09 pm
when fitting dyna s with origanal coils ,to cold fit what do you do..rig up a bulb and see it light when the f hits the mark...nb i don't have a strobe and I'm shite with a tester.cheers. :ghostface
Re: dyna s
#2 PostAuthor: zed1015 » Sat Nov 28, 2020 7:55 pm
No need for any bulbs etc, With the dyna fitted you will hear the plug fire with an audible tick even when it's still in the cylinder or you can just lay the plug on the head and view the spark.
You can static time on full 40 degs advance mark rather than the idle mark by holding the rotor fully clockwise against the bob weights as you turn the crank with a spanner.
Once set there's no real reason to strobe it as it won't alter when running.
