Tapered swing arm bearings
JimBoUK
#1 PostAuthor: JimBoUK » Thu Dec 10, 2020 6:24 pm
Hi folks,
So a while back I picked up a JMC deep braced swing arm for my GPZ1100 B1.
It’s a steel one, not ally.
The JMC has taper bearings where the original one has needle roller bearings.
After a google I can see you can get taper bearings for some swing arms.
How’s this gonna work ?
If I tighten the swing arm bolt to the recommended torque won’t it be too tight for the taper bearings ?
Re: Tapered swing arm bearings
#2 PostAuthor: z1bman » Thu Dec 10, 2020 7:47 pm
no the spacer between the two bearings determine the preload on the bearings
JimBoUK
#3 PostAuthor: JimBoUK » Fri Dec 11, 2020 1:53 pm
I guess that makes sense
JimBoUK
#4 PostAuthor: JimBoUK » Fri Dec 11, 2020 1:53 pm
