Swingarm needle bearings
scott
Junior Section leader
#1 PostAuthor: scott » Thu Mar 04, 2021 10:16 am
When fitting swing arm needle bearings, is it so that the manufactures markings need to be facing outward??
Re: Swingarm needle bearings
#2 PostAuthor: zed1015 » Thu Mar 04, 2021 10:20 am
The bearing aren't directional so can be fitted either way but having the numbers facing out make it easier to id the size when replacing in the future.
scott
#3 PostAuthor: scott » Thu Mar 04, 2021 10:22 am
Thanks Rob
