Z1b Sump
KwakaRascal
Z1b Sump
#1 PostAuthor: KwakaRascal » Wed Mar 31, 2021 11:14 am
I’m looking to remove the sump base casing whilst the engine is still in the frame.
Unfortunately I don’t have a bike lift, so going to be approaching this whilst on its centre stand.
Before I start, looking for any helpful tips as to how best to go about it.
My own concern is how to remove the remnants of gasket easily.
Re: Z1b Sump
#2 PostAuthor: zed1015 » Wed Mar 31, 2021 11:26 am
Razor blade or flattened copper tube to remove the gasket if it doesn't come off clean.
Once you have removed all the bolts a sharp tap sideways with a rubber/nylon mallet should break the seal.
There's no dowels on the sump pan.
Re: Z1b Sump
#3 PostAuthor: Philippe » Wed Mar 31, 2021 3:54 pm
Hi KwakaRaskal
do it just like zed1015 discribed and when you put a new gasket on, apply a thin coat of grease on it on both sides. This will help to remove it easy the next time.
Users browsing this forum: No registered users and 107 guests
