Z1000 float chamber issue
Gavin
#1 PostAuthor: Gavin » Mon Apr 05, 2021 1:33 pm
Hi guys
I have just noticed on No. 4 carb,one of the overflow tubes has cracked inside the chamber where it enters the casting, are these tubes available from anywhere or is it a new chamber required, unfortunately it is off a set of pumper carbs so is slightly different
Gavin
Z1000 MK2
Z1300 DFI
KeithZ1R
Re: Z1000 float chamber issue
#2 PostAuthor: KeithZ1R » Mon Apr 05, 2021 1:59 pm
clean it up, and solder the crack :up
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#3 PostAuthor: Garry.L » Mon Apr 05, 2021 2:01 pm
KeithZ1R wrote:clean it up, and solder the crack :up
What he said, if they're brass they should solder.
Gavin
#4 PostAuthor: Gavin » Tue Apr 06, 2021 2:20 pm
Cheers Keith & Garry,
It was cracked just below the point it enters the aluminium body, had a couple of tries with no success then decided the open the crack up a little and put lots of solder in, then drilled the tube clear of solder,
Jobs a good un it doesn’t leak.
Z1000 MK2
Z1300 DFI
Users browsing this forum: No registered users and 157 guests
