Oil in airbox
Gavin
Oil in airbox
#1 PostAuthor: Gavin » Mon May 03, 2021 10:11 am
Hi guys
What causes oil to end up in the airbox, the bike ran well during a motorway ride at a steady 70mph for 90 miles without a stop
Gavin
Z1000 MK2
Z1300 DFI
Re: Oil in airbox
#2 PostAuthor: zed1015 » Mon May 03, 2021 10:23 am
The air box is connected to the engine breather under the carbs by a little tube so oil mist does end up settling in the air box.
It's normal though unless it's swimming in it.
Over filling the motor or some blow by past the pistons will make it worse.
Gavin
Re: Oil in airbox
#3 PostAuthor: Gavin » Mon May 03, 2021 10:40 am
Rob
The oil was dripping onto the swinging arm, the last compression test was
In 2019
No1 = 138, No.2= 130, No.3= 128, No.4= 140.
Gavin
Z1000 MK2
Z1300 DFI
Re: Oil in airbox
#4 PostAuthor: zed1015 » Mon May 03, 2021 10:43 am
Not bad comp numbers and all within 15 psi from lowest to highest.
Maybe needs some more miles on it to see if it settles before looking at a possible hone and re-ringing or whatever.
compo z1r
Re: Oil in airbox
#5 PostAuthor: compo z1r » Mon May 03, 2021 12:35 pm
zed1015 wrote:Not bad comp numbers and all within 15 psi from lowest to highest.
if it needs a re-ring block off ie plug air box and re route to a catch tank temp of course till you get round to it saves a lot of stains and cleaning :D
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Mark Tiller
Re: Oil in airbox
#6 PostAuthor: Mark Tiller » Mon May 03, 2021 8:35 pm
higher mileage motors are best run mid window oil level
07962421462
rickm
Re: Oil in airbox
#7 PostAuthor: rickm » Tue May 04, 2021 9:20 am
Plus, you don't really want oil dripping off the swing arm onto the rear tyre when you're out riding.
H2B GPZ900R
steve452
Re: Oil in airbox
#8 PostAuthor: steve452 » Wed May 05, 2021 2:56 pm
Why not? It'd be just like riding an old Brit bike :rofl
Z1-B, 360bhp ZX1000NGF
Users browsing this forum: No registered users and 100 guests
