Gearbox 1973 Z1
Cauf61
Gearbox 1973 Z1
#1 PostAuthor: Cauf61 » Fri Jun 11, 2021 3:22 pm
Hello
My gearbox refuses to shift in the upwards direction ( 2.3.4.5) Down to 1st and neutral is perfect.Clutch is new and working fine.
Anybody has an idea what the cause could be ? Is it possible to work on the gearbox "in frame" ?
Grts
Patrick Belgium
z2.john
Re: Gearbox 1973 Z1
#2 PostAuthor: z2.john » Fri Jun 11, 2021 3:33 pm
This is normal. You cannot shift up unless the output shaft is turning
Re: Gearbox 1973 Z1
#3 PostAuthor: zed1015 » Fri Jun 11, 2021 3:35 pm
That is normal.
It's called the positive neutral finder.
You can't engage 2nd and above until the bike is moving or you spin the back wheel while on the center stand.
Cauf61
Re: Gearbox 1973 Z1
#4 PostAuthor: Cauf61 » Fri Jun 11, 2021 3:37 pm
Ok I will do the test.
Cauf61
Re: Gearbox 1973 Z1
#5 PostAuthor: Cauf61 » Fri Jun 11, 2021 3:38 pm
Would be great if normal. :-)
CAT3
Re: Gearbox 1973 Z1
#6 PostAuthor: CAT3 » Sat Jun 12, 2021 10:55 pm
There are three, (I think) ball bearings in one of the gearbox shafts, or the gear itself, that need centrifugal force to throw them out, which allows the second gear to move.
If you have a look at an exploded view of the gearbox parts you should be able to see these bearings in one of the shafts.
Cauf61
Re: Gearbox 1973 Z1
#7 PostAuthor: Cauf61 » Sun Jun 13, 2021 6:13 am
CAT3 wrote:There are three, (I think) ball bearings in one of the gearbox shafts, or the gear itself, that need centrifugal force to throw them out, which allows the second gear to move.
Thx
