Z1000-A1 pattern clocks fittng
TiBolts
#1 PostAuthor: TiBolts » Tue Jan 25, 2022 10:03 pm
The Z1000-A1 that I bought in bits came with lots of new spares, including some Hi Level clocks - but they don't fit the original bracket. The bulge on the back of each one fouls the bracket; the fittings etc otherwise line up as they should. Looks like I might be able to file away sections of the bracket but I wondered if anyone knows whether there's a pattern bracket that fits with these clocks?
Also I need to stick new foam on the back of the clocks - how thick should it be? The original stuff is shot to pieces.
Theo
Peteypops23
Re: Z1000-A1 pattern clocks fittng
#2 PostAuthor: Peteypops23 » Wed Jan 26, 2022 4:01 pm
Any photos of the offending articles mate?
Taffus
#3 PostAuthor: Taffus » Wed Jan 26, 2022 5:17 pm
There's an updated bracket for these. Ring zpower
TiBolts
#4 PostAuthor: TiBolts » Wed Jan 26, 2022 5:19 pm
Taffus wrote:There's an updated bracket for these. Ring zpower
Thanks - I will. I was gonna call Phil this morning but was too busy...
Taffus
#5 PostAuthor: Taffus » Wed Jan 26, 2022 5:26 pm
think i may have got mine from cybike, was awhile ago
TiBolts
#6 PostAuthor: TiBolts » Thu Jan 27, 2022 1:23 pm
Thanks all, yes spoke to Phil and they do one and I can see from the photo that it has a bigger space in the centre of each clock bracket. Also appears to come with the foam vibration damping stuff.
https://www.z-power.co.uk/clock-mounting-bracket
Ordered!
Andy M
#7 PostAuthor: Andy M » Tue Oct 04, 2022 7:58 pm
Dragging this out of the archives... What are peoples thoughts on these clock sets ??
#8 PostAuthor: chrisNI » Tue Oct 04, 2022 8:20 pm
Andy M wrote:Dragging this out of the archives... What are peoples thoughts on these clock sets ??
They work well at least the ones I have do no wavy needles any more. There was some mods needed to the bulb wiring as I recall and you couldn’t use the original bulb holders and wiring because they were different size.
rpeters
Bristol's "H" Hoarder
#9 PostAuthor: rpeters » Wed Oct 05, 2022 6:00 am
I have bought a couple of sets this year and they were fine. Everything fitted nicely.
paid up member
#10 PostAuthor: Ultim8pc » Wed Oct 05, 2022 4:26 pm
chrisNI wrote:There was some mods needed to the bulb wiring as I recall and you couldn’t use the original bulb holders and wiring because they were different size.
Correct!
