ELR Pingel with RS34's
Good afternoon all.
I have a 1984 Z1000R2 and there are a few bits I want to sort out, one being...
I noticed that it was leaking slightly from the stock vacuum Petcock, this was on both the side and centre stand. I have changed the innards of it at least twice in the last 3-5 years and i'm thinking of a Pingel as i'm getting fed up with it.
I have RS34's on the bike and I was wondering if the Pingel is a straight swap, ie when in position it's doesn't hit the top of the carbs?
Any alternative thoughts/ideas are of course welcome.
Stu
Stu
Re: ELR Pingel with RS34's
Pingels are taller than standard. I have a pingel fitted to my lawson with keihin cr33 carbs and it is close to the top of the carbs. On one of my bikes I have used two tank rubbers at the rear, just to lift it up slightly. The tank on that one is very different to a standard one, so might not be relevant.
Rob
Rob
Thanks Rob, I'll bite the bullet and give them a try.
Stu
Stu
I was too tight to buy one. My standard tap leaked a little for a long while even after throwing new bits into it twice. I had an old, but different (very similar) tap laying about and managed to rob the thin crinkle shim out of it and cram it into mine. It is a little stiff. You could say un-necessarily positive but has not leaked one drop for about three years. It will probably wear out the ported rubber ring prematurely but not in the time i have been using it in this way so far.
You may be able to find a new tap on line as the taps often fit various models, I found one for my ELR in the states a few years ago.
Thanks for the replies.
I've also been reticent to splash out on the Pingel, as they are ample coin.
I also managed to get a replacement a few years back, that leaked and so I replaced the innards and that leaked after a while. Which was a pain.
Rob.
Thanks, that's good news.
Is it a straight swop? Or does the tank hole need altering?
The current one has a slightly elongated hole due to the filter element.
Stu
Stu
STu,
Not on the Z1R, thats a straightforward male boss connection. I think you need the adaptor plate
I also have one on my Z1300 which has the elongated hole. The pingle will not fit through the slot, you need to file off a little material either side of the slot with a rounded file.
From memory it was the same with my old ELR which had the pingle treatment.
Rob
Rob
paid up member
Cheers Rob.
Stu
Stu
rpeters wrote:STu,
Rob
Had to do the same on the Z1000A2 tank with the slotted hole.
Gus
"Set the GRINDER on it"
Gus wrote:rpeters wrote:STu,
Rob
Gus
And the Mk2 tank on my Z1R as well..................
If I alter the current hole to fit the Pingel is there any going back? IE can the original (or equivalent) petcock be used?
I imagine it would be someone else's problem, but would like all the information before I decide.
Stu
Stu
I think the new hole would be pretty close to the seal. Measure you clearance between sea an measure Pringle filter to check
paid up member
Users browsing this forum: No registered users and 90 guests
