Running fault.
Cville
Running fault.
#1 PostAuthor: Cville » Sat Feb 05, 2022 3:24 pm
Hello, does anyone know if I can use kz1000 pick up coils on a z650F3.
Thanks.
Re: Running fault.
#2 PostAuthor: Philippe » Sat Feb 05, 2022 4:42 pm
Hi Cville
I'm not sure but they look the same, the plates where the pick up coils are mounted upon have a different number but I think that is because the mounting plate of a Z1000 is bigger than that of a Z650.
When changing the coils and the magnets take care how you place the magnets on the mounting plate! They need a specific way of mounting.
Cville
Re: Running fault.
#3 PostAuthor: Cville » Sat Feb 05, 2022 5:26 pm
Thanks Phillipe,
Do you know the ohms reading of the coils from new, as I have read that they need to match the coils
And the ignition system in general .
