Hi again lads,
I have to change the oil ring on one of the pistons on the 1000r
Looking up the parts catalogue, there are to different nos. depending on if it is an R1 or R2, I have an R2 but curious and also want to make sure I get the correct part, any ideas what the differences would be?
Part nos. are 13024-5018 and 1324-5024 ring-set piston LL,O/S 1.00?
P
oil rings-Z1000R
Re: oil rings-Z1000R
13024-5018 is no longer available 13024-5024 is available at cradley. as i said in your other post the pistons & rings where modified 13024-5018 is an old number the modified rings especially the oil control rings are teflon coated so if you require 1mm oversize you need 13024 5024
Skid Mark wrote:Hi again lads,
P
Talk to Cradley Heath Kawasaki - they should know the difference - they have 1324-5024 in stock.
ADRIAN H wrote:Skid Mark wrote:Hi again lads,
P
i worked for cradley for over thirty years
Lads,
Thanks for the swift reply. At this stage I don't want to leave anything to chance.
I don't know how people managed before forums like this!
I would be gone bald if I couldn't bounce these type questions off you.
P
P
z1bman wrote:ADRIAN H wrote:Skid Mark wrote:Hi again lads,
Looking up the parts catalogue, there are to different nos. depending on if it is an R1 or R2, I have an R2 but curious and alsowant to make sure I get the correct part, any ideas what the differences would be?
P
i worked for cradley for over thirty years![]()
Cool, good place for parts
P
I suspect 1324-5024 is a replacement reference number for 1324-5024
P
main dealers parts data base are more up to date than the online ones. cradley have one of the largest stocks in europe
