Fitting new cam chain
shaggy
#1 PostAuthor: shaggy » Tue Dec 27, 2022 4:12 pm
Am rebuilding a Z1B engine am fitting a new Kawasaki genuine part cam chain have noticed the old chain has 2 white paint marks on it should I transfer the distance of these onto the new chain before fitting it to the crankshaft
Excuse my stupidity but all my previous engine work has been on 2 strokes
Re: Fitting new cam chain
#2 PostAuthor: zed1015 » Tue Dec 27, 2022 4:20 pm
The simple answer is no.
Marking the chains 28 pin count will be meaningless until the new chain is fitted.
#3 PostAuthor: Z1streetfighter71 » Tue Dec 27, 2022 4:23 pm
Dont bother, these are marked when setting your own, 28 teeth from timing mark to timing mark. you will have to do all this your self later.
#4 PostAuthor: Z1streetfighter71 » Tue Dec 27, 2022 4:23 pm
You beat me to it Zed.
shaggy
#5 PostAuthor: shaggy » Tue Dec 27, 2022 4:26 pm
Thanks for the reply’s sure it will be the first of lots of stupid questions so although have been on here about 12 years have finally put my hand in my pocket and joined the club
#6 PostAuthor: Z1streetfighter71 » Tue Dec 27, 2022 4:32 pm
No such thing as a stupid question mate, better be 100% in the know when it comes to engine building, so ask away.
#7 PostAuthor: zed1015 » Tue Dec 27, 2022 4:57 pm
Z1streetfighter71 wrote:Dont bother, these are marked when setting your own, 28 teeth from timing mark to timing mark. you will have to do all this your self later.
Actually 29 pins from mark to mark to keep it simple and avoid Kawa's devious plan for the unwary who don't fully read the instructions :lol:
#8 PostAuthor: Z1streetfighter71 » Tue Dec 27, 2022 5:14 pm
Ah yes..always read the book!
gray
#9 PostAuthor: gray » Tue Dec 27, 2022 8:23 pm
yes - that's caught me out a few times. The diagram only helps a bit. The timing mark points to pin ZERO and you count from there. If you call the pin next to the mark pin 1 then you'll be wrong and the inlet cam will be a pin out
I think the paint marks were for the original factory assembly and were completely irrelevant after that
gray
#10 PostAuthor: Z1streetfighter71 » Tue Dec 27, 2022 9:33 pm
The reason i said teeth and not pins is i have always counted the gaps (where the teeth would be) and not the pins, 28 teeth between 29 pins. Sorrry for being pedantic.
Users browsing this forum: No registered users and 77 guests
