Stator coil removal from casing
shaggy
#1 PostAuthor: shaggy » Wed Jan 04, 2023 3:20 pm
Trying to remove stator coils from one casing to put into new one have removed the 3 bolts holding it in but is in as tight as the proverbial ducks bottom how do I remove without damaging it please.
Re: Stator coil removal from casing
#2 PostAuthor: zed1015 » Wed Jan 04, 2023 4:41 pm
Tap the case gasket face down a few times on the bench and the windings usually come out.
If they are really stubborn you may have to warm the case to expand it a little.
Hair dryer or hot air stripper usually does the trick.
gray
#3 PostAuthor: gray » Wed Jan 04, 2023 8:31 pm
wait till the wife/ partner's out. Sneak into the kitchen , fill the washing basin half full with boiling water from the kettle then float the case in it ( interior of cover uppermost). Don't overfill it so water gets inside the cover
10 mins later and the alloy cover will have expanded off the stator and the stator will fall out. Use rubber gloves to lift it out cos it'll be hot.
Clean basin well with soapy bubbles and sneak outside with stator, cover and a celebratory beer.
gray
shaggy
#4 PostAuthor: shaggy » Wed Jan 04, 2023 9:41 pm
Will try that tomorrow when wife’s gone to work
KeithZ1R
#5 PostAuthor: KeithZ1R » Fri Jan 06, 2023 9:10 am
gray wrote:wait till the wife/ partner's out. Sneak into the kitchen , fill the washing basin half full with boiling water from the kettle then float the case in it ( interior of cover uppermost). Don't overfill it so water gets inside the cover
That proper made me laff :lol: :lol:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
shaggy
#6 PostAuthor: shaggy » Fri Jan 06, 2023 5:00 pm
The bowl of hot water worked a treat thanks and the missus knows nothing about it
wilsonsjw11
#7 PostAuthor: wilsonsjw11 » Sat Jan 07, 2023 10:16 am
Excellent advice offered on here as always.
Regards
Steve
Users browsing this forum: No registered users and 77 guests
