A set of bandit carbs have been offered to me. Im wondering would they work on my gpz 1100 they are from a 97 N. I'm sure iv seen on here a set from a gsxr 750 will work.
Any information would be appreciated
Paul
Gpz 1100A1 carbs
- Z1streetfighter71
- ZedHead
Re: Gpz 1100A1 carbs
The carb spacing is the same at 77-93-77 but the lean forward on the bandit 1200s cylinder block is a 10 degrees more than the Gpz so the float bowls will be at an angle, there is a bit of tweaking on the that issue from what i hear, i also read somewhere thats it can be finicky on a cold start but the Japanese lads run Suzuki carbs on Z1000s all the time. Better men on here might know a few more specifics than me.
- new poster
Thank you I wasn't to sure & no point spending money on them if they would be troublesome
1000J and Z1100 carbs are the usual swap for the GPZ injection.
- warren3200gt
Got a set of thou J carbs knocking about here someplace.
