Splitting Z1000J Crankcase
kawasaki_man
#1 PostAuthor: kawasaki_man » Mon Sep 11, 2023 9:54 pm
Hi, just need some advice / confirmation regarding the splitting of the crankcases on a Z1000J.
I've removed most of the outer cases and their parts with the exception of the alternator rotor(& starter clutch assembly) and the clutch hub. Can I proceed to split the cases with these two items still in place?
Thanks for any advice you can give me.
Re: Splitting Z1000J Crankcase
#2 PostAuthor: zed1015 » Mon Sep 11, 2023 10:17 pm
Yes! The cases will split with those components still attached
#3 PostAuthor: Al » Tue Sep 12, 2023 10:25 am
The 8mm bolts that join the front half of the crankcases together are made of finest bone china and would rather sanp than un-do. This is particularly true of the outer ones and specifically the left hand side ones. If they snap they usually snap flush which makes it a nightmare to get them out!
A couple of the very long 6mm through bolts are similarly inclined.
kawasaki_man
#4 PostAuthor: kawasaki_man » Tue Sep 12, 2023 8:09 pm
Many thanks for your help and advice zed1015 & Al.
I'll see how it goes over the next few day.
