Z1000 Connecting Rod Big End Side Clearance
Speedie
#1 PostAuthor: Speedie » Fri Oct 27, 2023 2:34 pm
Hello All!
My N04 connecting rod side clearance is 0.5mm (Z1000) The standard is 0.3 - 0.4 with a service limit of 0.6mm. All the others are within spec.
At 0.5mm should I be concerned and need to get it looked before it goes back in or is this normal?
Many thanks!
Paul
Re: Z1000 Connecting Rod Big End Side Clearance
#2 PostAuthor: zed1015 » Fri Oct 27, 2023 2:48 pm
0.5mm is within service limits so use it..
Speedie
#3 PostAuthor: Speedie » Fri Oct 27, 2023 3:12 pm
zed1015 wrote:0.5mm is within service limits so use it..
Thanks Rob, for the quick reply!
