Hi, I am looking for a replacement head for my Z900 a4, if anyone can help? Not sure if the early Z1000 heads are the same.
Thank you, Neal
Z900 A4 Cylinder Head
Re: Z900 A4 Cylinder Head
they will fit just have 8mm exhaust studs.
Any z900/1000 head up to the the MK2 will fit with the main difference being 6mm exhaust studs on the early heads and 8mm on the later ones.
All the valves etc are the same ( except for the injection models ) and the mk2 heads have a minor casting difference near the cam end plugs which is only visual and barely noticable.
thewormman
- Regular Poster
What are you doing with the old head?
What is wrong with it?
i will try and post some photos tomorrow
thewormman
- Regular Poster
CDNeal wrote:i will try and post some photos tomorrow
