GPZ 1100 starter
Skid Mark
GPZ 1100 starter
#1 PostAuthor: Skid Mark » Wed Apr 17, 2024 5:18 pm
Hi all!
Can anyone advise if the 1000j/r starters are interchangeable with theGpz1100 untrac starters, pretty sure they will fit but wondering if the extra load( 1170 big bore) will damage The thou starter. I need to replace the starter and need the bike. I’m hoping I can get it rig my thou r starter temp until I can get a replacement.
Thanks in advance.
P
Gus
Re: GPZ 1100 starter
#2 PostAuthor: Gus » Wed Apr 17, 2024 6:02 pm
All these
This Kawasaki 21163-1143 STARTER MOTOR fits the following models and components:
Aftermarket Parts Electrical Starters Starter Motor
Kawasaki Motorcycle 1993 Police 1000 - KZ1000-P12 Starter Motor
Kawasaki Motorcycle 1994 Police 1000 - KZ1000-P13 Starter Motor
Kawasaki Motorcycle 1991 Police 1000 - KZ1000-P10 Starter Motor
Kawasaki Motorcycle 2003 Police 1000 - KZ1000-P22 Starter Motor
Kawasaki Motorcycle 2005 Police 1000 - KZ1000-P24 Starter Motor
Kawasaki Motorcycle 1995 Police 1000 - KZ1000-P14 Starter Motor
Kawasaki Motorcycle 2000 Police 1000 - KZ1000-P19 Starter Motor
Kawasaki Motorcycle 1990 Police 1000 - KZ1000-P9 STARTER MOTOR (KZ1000-P9/P10)
Kawasaki Motorcycle 1999 Police 1000 - KZ1000-P18 Starter Motor
Kawasaki Motorcycle 1983 LTD Shaft - KZ1100-L1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 GPz - ZX1100-A1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1985 LTD Shaft - ZN1100-B2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1986 Police 1000 - KZ1000-P5 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1996 Police 1000 - KZ1000-P15 Starter Motor
Kawasaki Motorcycle 1985 Police 1000 - KZ1000-P4 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Police 1000 - KZ1000-P2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1982 Eddie Lawson Replica - KZ1000-R1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 2002 Police 1000 - KZ1000-P21 Starter Motor
Kawasaki Motorcycle 1984 Police 1000 - KZ1000-P3 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Spectre - KZ1100-D2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1992 Police 1000 - KZ1000-P11 Starter Motor
Kawasaki Motorcycle 1982 Police 1000 - KZ1000-P1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Eddie Lawson Replica - KZ1000-R2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1982 Spectre - KZ1100-D1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1984 GPz - ZX1100-A2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1984 LTD Shaft - ZN1100-B1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 2001 Police 1000 - KZ1000-P20 Starter Motor
Kawasaki Motorcycle 1998 Police 1000 - KZ1000-P17 Starter Motor
Kawasaki Motorcycle 1982 KZ1000-J2 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1983 KZ1000-J3 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1981 KZ1000-J1 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1983 KZ1000-J3 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1981 KZ1000-J1 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1982 KZ1000-J2 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1981 LTD - KZ1000-K1 STARTER MOTOR/STARTER CLUTCH (KZ1000-K1)
Kawasaki Motorcycle 1982 LTD - KZ1000-K2 STARTER MOTOR/STARTER CLUTCH (KZ1000-K1)
Kawasaki Motorcycle 1981 CSR - KZ1000-M1 STARTER MOTOR/STARTER CLUTCH (KZ1000-M1)
Kawasaki Motorcycle 1982 CSR - KZ1000-M2 STARTER MOTOR/STARTER CLUTCH (KZ1000-M1)
Kawasaki Motorcycle 1981 CSR - KZ1000-M1 STARTER MOTOR/STARTER CLUTCH (KZ1000-M2)
Kawasaki Motorcycle 1982 CSR - KZ1000-M2 STARTER MOTOR/STARTER CLUTCH (KZ1000-M2)
Kawasaki Motorcycle 1983 Shaft - KZ1100-A3 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1982 Shaft - KZ1100-A2 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1981 Shaft - KZ1100-A1 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1983 Shaft - KZ1100-A3 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1981 Shaft - KZ1100-A1 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1982 Shaft - KZ1100-A2 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1997 Police 1000 - KZ1000-P16 Starter Motor
"Set the GRINDER on it"
#3 PostAuthor: zed1015 » Wed Apr 17, 2024 6:06 pm
Yes! J/GPZ 998cc/1089cc starters are all the same 4 brush type.
Skid Mark
#4 PostAuthor: Skid Mark » Wed Apr 17, 2024 6:14 pm
Thanks for confirming Gentlemen.
I was about to chance it and then said I would check here just to be sure.
