Carb orings
Carb orings
Hi I’m wanting to strip n replace the oring sun my carbs Z1000R2 dose anyone apart from Z power do a kit?
Re: Carb orings
Whatever kit you buy make sure they are VITON rubber otherwise it's a waste of time with the ethanol fuel we have.
There's one or two sellers on Ebay that do Viton O' ring kits for bike carbs so check there first.
Re: Carb orings
Agree with zed1015 about using viton, especially for the float valve seat. I used original kawasaki ones a few years ago, cost a fortune, and they started to overflow in 1 and 2 recently. Replaced them with viton ones from simplybearings, which solved the problem and look forward to many years using E5. I think they were 1.5mm section 7mm bore - £4.72 for 10pc
Users browsing this forum: No registered users and 100 guests
