compression figures Z1000
Hard Road
#1 PostAuthor: Hard Road » Thu Sep 26, 2024 5:04 pm
not got myself a manual yet but i read on another thread that the standard Z1 900 compression figures are 121psi !!!!! that seems low to me compared to other makes of bikes.
anyone got the numbers for a 1978 Z1000 ?
I checked mine and they are between 135-140 psi.
Re: compression figures Z1000
#2 PostAuthor: warren3200gt » Thu Sep 26, 2024 5:19 pm
Hard Road
#3 PostAuthor: Hard Road » Thu Sep 26, 2024 5:45 pm
nice one thanks :wink:
standard 128-156 psi, and mine is in the middle, and that was after its first start after 6 years, things will only get better :D
#4 PostAuthor: Ultim8pc » Fri Sep 27, 2024 9:31 am
Factory minimum spec is 105PSI with no more than 15psi between any two cylinders.
Hard Road
#5 PostAuthor: Hard Road » Fri Sep 27, 2024 12:11 pm
Ultim8pc wrote:Factory minimum spec is 105PSI with no more than 15psi between any two cylinders.
mines a long way off from the minimum and due to it standing for over 6 years im sure it'll get better after some miles, its got 17.000 miles on its clock so i think its not a long way from being true !!!
ive got a 1980 GSX1100 with fairly good compression that stood for a long time with less than 10,000 miles on it, and after a few 100 miles the compression as come up to top spec. :wink:
Users browsing this forum: No registered users and 81 guests
